メインコンテンツにスキップ
HP Elitebook 6930p announced in September 2008 and was one of the first generation EliteBook laptops. It was advertised as the first laptop to break the 24 hour battery life barrier.
18回答 すべてを表示
Laptop lid won't latch
The lid of my laptop no longer latches.
There are two posts on the lid which snap into recessed holes on the body. It seems there might be springs which grab the posts, but have lost their "springiness". The posts no longer latch into place when I close the lid.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
Unfortunately, there's not much you can do in this circumstance; it's a problem that most aging 6930's see, and HP has since made design changes to improve the latching mechanism.
You could try replacing the base cover with a newer one, as that assembly should be included, or try bending the spring-pushed latching bar to have a better grip. Both require a considerable amount of work, tearing the machine down to it's core, and aren't guaranteed to resolve the problem.
The new LCDs have thinner clips that latch easier, and the internal latch bar is metal instead of plastic.
I, sadly, had to replace the base cover on about 2000 machines in 2009-2010.
Good luck!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
That had to be a horrid experience, I had 2 of them, person I know had about 50! Big deal to just fix those pins. I did not have much money in them although they were refurbished so they were ok. I did take some small channel locks and "gripped" each pin and tried to bend it towards screen and it worked good on one pin but not so good on the other,it being in a plastic (or what ever material) It was a sure accident waiting to happen so left it with one pin catching. If I would of had a amount such as you 2000 being a toolmaker and used to dealing with horrid situations I think I would have looked at another fix but never opened it up so don't know what you would be facing as an option to tearing the thing apart 2000 times.
さんによる
コメントを追加
最も参考になった回答
I tried bending the pins forward a small amount,it got one pin to catch when shut. But I was holding my breath as I am a tool maker and know "bending" that small pin is risky and a short way to fix it. But unless you are mechanically inclined and tech savvy, I would just get a stick on Velcro strip and place a piece on each end
Safer and I also noticed the screen or lid had a slight warp in it. So if yours also is warped(lol couldn't help it) I would go with my Velcro fix.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Hi. As Bobby said , I tried bending the posts downward and it worked . However you should be careful of not applying too much force that might break the posts or even cause worse problems
さんによる
コメントを追加
Having read this thread I replaced the base and yes it did involve a considerable amount of work. Once completed I had the same problem. I therefore turned my attention to the pins. With the screen bezel removed I found I could bend each pin slightly towards the base, this I did and I placed a spacer behind each pin block. I then reassembled and "Hey Presto" one working catch.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Glad that worked my friend, i posted the "quick fix " and i could only get the left pin to catch. It is scary bending something that is not suppose to be bent tho! HP is aware of this and WAY on down the road did a fix for it...but I bet almost everyone with that model has the same problem. Velcro works but tacky. Good luck and glad that worked for you.
さんによる
Ps ...like your screen name. use to watch Johnny every night. Best ever!
さんによる
コメントを追加
The left lid latch didn't work on my (12 yr old) new-to-me HP 8760W. It's apparently been an old workhorse/battleax, I can see it's been opened numerous times before, but at least the case and ribbons/connectors damage is minimal. Guessing the tech was fairly competent. Reason I was inside was for CPU and video card upgrades and cleaning, and evaluation of internal condition. While in there I inspected and repaired the mount for the latch where the threaded insert had broken out of the base cover. When done I had the latch release slider mechanism working and aligned to my satisfaction, but the lid still didn't latch on the left side, I decided to table that issue for the time. After reading this thread today I considered it and decided that perhaps bending the pin was worth a try, so I did a little and it kind of caught, but would still slip out. Then I looked closely and decided maybe a little twist and a little more bend in the pin might help... and PRESTO! It actually latches now!!! Thanks for this old thread and all who participated!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Dalbey さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 26
今までの合計 8,457
