メインコンテンツにスキップ
The Nikon Coolpix S8200 has a 14X optical lens, a monitor that is 7.5 inches wide, and weighs approximately 7.6 oz.
8回答 すべてを表示
Keep getting "lens error" message
With my Coolpix S8200 camera, I keep getting "lens error" on my screen. I have turned my camera off and on multiple times and replaced the battery with a new one but nothing seems to be helping. Is there anything I could do to try and get this camera working again?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
If you have already tried restarting the camera as well as replacing the battery, then the next step in the process would be trying to replace the lens of the camera. You should be able to follow the steps for this process on ifixit. If there is not a guide on how to replace this part or if this solution also fails, then the next step would most likely be replacing the camera itself. Hope this helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ashley Wilbur さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 847
