Magsafe adapter doesn't work. What should I check?
Hi.
My Magsafe 1 AC adapter (from Macbook Air, 45W) doesn't work suddenly. No LED indication what so ever. No damaged visually find, even wire is fine.
I have a volt-meter, so I can check some resists or volt. Please let me know what should I check...
These are current status :
Pin 1+2 : Not shorted. 0.44V, 200k Ohm when not plugged in, 5M Ohm when plugged in.
Pin 4+5 : Not shorted. 0.44V, 130k Ohm when not plugged in, 2M Ohm when plugged in.
Pin 1+5 or 2+4 : Shorted, 0.0V, 0 Ohm
What I heard, it should about 6V when it's not connected to notebook. Mine does 0.4V only.
Help me please.
この質問は役に立ちましたか?
1件のコメント
Standby output of Apple's MagSafe Power Adapters varies between models. Yes it is often said to be "6V", but that is "old knowledge" which pre-dates 45W and MagSafe 2 models. (I'll share two standby potentials which I measure: Model A1424 is around 3,15 V; Model A1435 is around 0,6 V.)
Unfortunately, I am not able to help you with your misbehaving unit. I hope this little bit of knowledge will be useful to anyone, whom suspects their unit is faulty just because its output potential is not 6 volt.
unsubstantiated さんによる
