Where is MacBook Air 13" 2012's thermal sensor?
Where are the thermal sensors in this computer?
One of my thermal sensors output a constant value 255, which is interpreted by Mac OS X as overheat(and the OS then throttles the processor), although the temperature is in fact normal.
Want to find and disconnect or short this sensor.
Where is the thermal sensor?
I searched online and found the color of the sensor is a tiny separate light or dark green PCB in other Macbook models, with a surface mounted 3-pin component like a transistor.
See:
http://www.macking.co.uk/media/catalog/p...
But this piece does not exist in the Macbook Air 2012.
I looked into the motherboard picture on Macbook 2012, there are two light green components on the back side of CPU, are they the thermal sensors?
Thank you all for help!
この質問は役に立ちましたか?
