メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3531回答 すべてを表示
Why does placing bottom screws stop home button from working?
Did a full screen replacement, after the previous owner tried to do it and didn't use a guide or didn't follow instructions to keep most of the parts. Had to also replace the home button because they ripped the original cable. Was able to get the phone fully functioning with all pieces from ifixit, including the two bottom screws, but now when I place the screws in to lock down the screen, the home button goes unresponsive and none of the clicks will register. Does anyone know why this happens? The home button will remain responsive without the screws installed.
Fyi most of the shielding that is installed in the phone to keep the cables protected is missing and so are the screws. The home button does not have any of the protection plates that were originally installed with the phone.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
There is a connector which connects the home button to a power source at the bottom of the phone. When the screws are taken out, the home button is disconnected from that power source (probably due to the screen raising a little) and the home button no longer works.
You can try putting the screws back in, and see if it works. If the home button still doesn't work then there's a problem.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The home button works without the screws so I don't think that this is the problem
さんによる
コメントを追加
Push the screen down and see if the home button works could be that the pressure is making the cable short
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You said most of the screws were missing, if you haven't replaced them Ifixit sells the entire set of screws for the iPhones or try Amazon. If screws are missing, that's a good way to have connection problems & more
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
uberdoll さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,139
