メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
328回答 すべてを表示
Changed wifi airport adapter - hardware not installed
Hi,
My macbook was working fine until i dropped water at him.
I dried all computer and turned on. Everything were working well, except the wifi that are showing the message: "No hardware Installed."
I tought weird, because bluetooth was still working, but wifi doesn't.
Even that, i bought an airport adapter and installed. But the message still there: "No hardware installed".
What could be the problem? What can i do to solve that?
Best regards!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
If you got a new Airport card and still are having issues, the connector on the motherboard may have been damaged. I would check the 'About the Mac' window and look at the system report to see if the system detects an airport card. If not, you could try an OS X restore. Otherwise, this issue is hard to fix...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hello Jake,
I've tried many ways to fix, but the solution was clean the contact of airport and re-install it. That works fine. Thank you for your answer.
さんによる
Glad to hear it it working again. I would've never thought to clean the contacts.
さんによる
コメントを追加
回答を追加する
Rafael Poli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 247
