Why is my SD card stuck?
I can't get my SD card out!
You probably inserted the SD card the wrong way. To remove it, gently pull with a pair of tweezers. To properly reinsert the SD card, place the camera down with the screen facing up towards you. Put the SD card in with the front of the card (usually shows brand name and data limit) facing up.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 1,747
