メインコンテンツにスキップ
Mac Proとして知られるデスクトップMacシリーズの2013年版新モデルです。
117回答 すべてを表示
締切られた回答
Fan ZIF Connector Pinout
Looking around I can't seem to find out what the pinout for the zif socket for the top exhaust fan is. It appears that the socket has multiple contacts and I'm not sure what each of them do. I'm looking for the ground and the 12v line. Is there a way that I can test each pin to see their function?
Thanks, Jordan
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I still haven't found a viable pinout for this fan but I did some snooping around the PCB with a multimeter and found what these pins do! Using the high res images from ifixit I made a diagram based on what pin connects to what on the PCB. Fan registers in BIOS and in the OS and throttles up and down with PWM..
In my photos there are 4 contacts to the left of the mezzanine connector that I assumed were for wires.
Pin 1 - 12v
Pin 2 - Tach/Sense
Pin 3 - PWM
Pin 4 - Ground
This pinout will give you a working fan with PWM and Sense functions
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 311
