メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
This is a Notebook by Acer. Within this document you will have access to guides and a troubleshooting page. This will hopefully allow you to solve issues you may be having with your Notebook.
23の回答 すべてを表示
Why did Windows fail to start?
when switching on and F8 button is pressed for a basic startup I opted for 'launch startup repair'.
the screen just changes to:
status 0x0000225.
boot selection failed because a required device is inaccessible.
I cannot get any other response from the computer. it will not even respond to the first of the recovery discs to reinstall windows.
I have researched several websites but no success.
help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try ESC or DELETE keys instead of F8 to get into BOOT OPTIONS and see what it is set to boot from..You may have to go into your BOIS to find this out..
OR...
Check the Hard Drive? Hook it up externally to another computer and see if you can access it..If not, see if it is listed in your Disk Management list. If it does not show up, I would say it was a bad Hard Drive. It's usually a Master Boot Record corruption, but your getting a required device is inaccessible message...not an MBR corruption message.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
N Walters さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 396
