メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
締切られた回答
How do I go about removing it?
I ordered a motherboard knowing that my mobo was shot due to liquid damage. I eventually took it apart and found very bad corrosion underneath the mobo. The xbox would still function and play games but would eventually shut off. So now that i have a new mobo comming my way like an idiot i just noticed that the processor seems to be soldered into the mobo that no longer works...how do i go about removing it and putting it in my new motherboard?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
well looks like no matter what measure i took to fix it i end up with another problem...I do not have a workstation or know of anyone with one...i was hoping i would learn how to fix this myself but now i just hit a dead end...looks like i need to return the mobo:/..
さんによる
Check with https://www.ifixit.com/User/721921/steve... It seems like he is pretty knowledgeable and may just be the help you need to get it fixed.
さんによる
コメントを追加
2件の回答
ベストアンサー
mhunt609, this will require a rework station. It is a BGA IC and will require removal with either hot air or IR station. After that you will most likely have to reball it and solder iut back onto the new board.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
New Motherboard should have the CPU on it.....I have never ordered a board that didn't have one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 107
