Dropped ipad mini. Now lines run thru display. Which parts need fixed?
I searched the site but cannot tell if it is LCD, Digitizer, both or something else.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The Lcd is responsible for displaying the picture and the digitizer is responsible for sensing touch. The lines on the screen signal a damaged LCD.
If the screen cracked you will probably want a LCD/Digitizer part. If not you can try to replace just the LCD.
このアンサーは役に立ちましたか?
Thank you. I've been successful with ifixit repair kits in the past. I will give it a try.
Your welcome and best of luck with your repair.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 228
