Why isn’t my phone turning on?
The lights on the display are off. I took out the cord and then plugged it back in, but it still isn’t working.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Check to see that all the cables connecting to the phone are correctly attached. You should be able to hear a “click” when you connect the wires successfully. If the phone is still not turning on, then it’s possible that there is an issue with the circuit board. Refer to the replacement guide for new circuit board. More information can be found on our troubleshooting page.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 194
