メインコンテンツにスキップ
The Azpen A701 is a 4GB Wi-Fi tablet running on Android. It was released in July 2013.
My tablet won't charge. What can I do?
Whenever I try to charge my tablet it will not charge. What could be causing this and how can I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
最も参考になった回答
you have replaced the charging cable, right?
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Same problem - the tablet crashed and won't boot, then I noticed the charging light blinked erratically and finally refuses to light up. I have tried several known good (tested on my smartphone) cables and wall chargers, and none of them will charge the tablet.
さんによる
コメントを追加
The battery might be dead. Also, make sure the device is plugged in properly when charging. It is also important to make sure the charger cable is not damaged.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Any suggestions for where to buy a replacement battery?
Also - would a bad battery keep the tablet from turning on if it's plugged in and charging?
さんによる
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,068
