メインコンテンツにスキップ
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212回答 すべてを表示
Recently, the CPU fan started running at full speed. What is wrong?
The CPU/Video fan runs slow at startup, and gets ridiculously fast and loud after a few minutes.
I disassembled the computer to remove 3~4 years of dust on the heat pipe fins, but the problem remains.
It is the nVidia logic board GPU that is running at 160 deg F. It has the CPU/GPU fan running at a full 3600 RPM. Is this in spec or am I going to need to try to re-seat the heat pipes to get a better thermal connection?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
did you replace the thermal paste on the cpu/gpu?
i had a few macbooks with heat problems, the paste was hard and almost useless - in other cases, there was way too much of that stuff on the chip's (original apple!).
replacing it is a must!!
このアンサーは役に立ちましたか?
スコア 5
5 件のコメント:
+ although nick recommended the thermal paste first, I'm gonna uptick ya. LMAO
さんによる
no, he edited it in his answer after i wrote it - as always (check the history - but i think he will delete his post soon - also as always)
さんによる
you are aware that everybody can see the "edited by" and of course the history of a posting.
さんによる
@ Markus...I was being sarcastic. LOL
さんによる
;-) and nick, it's not that "I" have a copyright on the stuff i'm writing. but it's lame to edit the stuff of an answer in the own answer - only to - yeah - only to what ? get a better reputation score? it's like the deleting stuff that you always do - i delete my answers if the worst case happens and mayer, majesty and answer at the same time - like a few minutes ago.
さんによる
コメントを追加
Try downloading a demo of iStat menubar.
Then you will get a good look into the CPU processes and temperatures in your iMac.
heres the program
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
If you'd given a link you'd have gotten an upvote.
さんによる
i edited this with a link
さんによる
コメントを追加
You could also try Activity Monitor, which is included with OS X.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jeff さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,541
