メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
Motherboard repair U701 voltage
My TAB2 doesent show eny lifesign at al.
I meschure voltage on U701 WICH SHOULD BE 1,2V
it is 0,9v not shure if that is the problem?
How to test the ON OFF switch?
Cant find this in the repair manual.
Charging seems to work, batterypower is 4.0v.
regards, patrik
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
patrik, check the voltages on the other components as well. Check the U701 output voltage on C732 > 1.3V, C733 > 1.8V, C734 > 1.2V, C735 > 1.2V C736 > 1.2V. If you do not get that voltage you should replace it. I'd consider a new power flex first. As for the switch, it appears to connect at pin 1 and 2 on HDC500.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you for fast answer, i have al the voltage you sugest exept for 1.2v at C734 and C736 that is only 0.9v
Also i mesure charge 5.0v at C508
Do you Think the ribbon Cable could still be faulty when i have 5.0 v at C508 and it sems that battery is charged at 4.0v ?
Is ribbon Cable at al used exept for charging?
Best regards from Sweden!
さんによる
コメントを追加
Patrik. I happen to have exactly same problem with a P5110 I have for repair: all voltages except for 2 are ok. The 2 off are exactly the same wrong voltage of 0,9V.
I have done, according to samsungs service manual, a replacement of U701. Unfortunately the problem is exactly the same with the new chip in place.
Next thing I will try is to swap out the oscillator OSC700. I will keep you posted with the results in the coming days.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Great Gido! My tablet died in my hands when i put the charger in. At first i thought it was a bad battery so i bought a new Samsung original battery. Unfortunally no luck with that.
Whould be nice if somone could sugest comon problem with this tablet.
さんによる
Just received the new OSC700. Replaced the OSC700 and now there is a clock signal again on the oscillator. Unfortunately the 2 voltages are still too low (0,9V) and tablet does not power on.
I will dig deeper to see if I can find the problem. To be continued...
さんによる
Gido, I have the same problem 0.9v. You repaired?
さんによる
@Gido Nijenhuis - Did you get to the bottom of this? Where did you get the chips/components from? Thanks.
さんによる
i had same problem, but still looking how to access U701 ic, my battery is 4 volts, I already charge it separately, still dead tablet, I wish to hear from you, thanks for sharing
さんによる
コメントを追加
回答を追加する
patrik さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,441
