I dropped my phone in the water and the screen is bubble
It was in the water for about 3 seconds if you could find out how to fix it that would be great
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Well, the first question would be did you submerge your phone in rice for a couple days and does the phone still function?
If the phone does not turn on, then you most likely have a display problem if the screen is bubbling. If I were you, I would replace the screen display. Here is the link to that page: iPhone 5s Screen
I also use this guy on eBay for a lot of my parts. He is very reputable and trusted: http://www.ebay.com/itm/LCD-Touch-Screen...
Hope this helps and please keep us updated on your progress and if you have any questions.
このアンサーは役に立ちましたか?
Yea it was in rice for a day and Thx I will check him out
Hi,
I have completely submerged my iphone 5s in water, was working for about 1/2, then switched off, will not turn on only shows a low battery, then the apple logo appears with a white background. The screen goes black with white lines. Can this be fixed?
Do not try to turn it on again. Take the screen off the iPhone and Immediately submerge the iPhone in 70-90% isopropyl alcohol for a good hour. Then take the iPhone out of the alcohol and let it air dry for a good 1-3 days. Once you do this, then you need to replace the screen and the battery. This has a success rate of 70-80% so if it doesn't work, then don't be discouraged.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 5,944
1件のコメント
My sister gives her iPhone 5s to me but now there bubbles on the left on the screen and I use some tape on the phone to got the bubble come always but is not working. What the good thing to use for small bubble on left corner screen.
Sophia Zuniga さんによる
