メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
締切られた回答
White Screen won't go away?
I know this is a fairly common problem with this model of iPod since i've been working on them for the past year, however, this time out of the 70 or 80 that I've done I cannot get it to stop white screening. The ports are fine, I have shorted the board between the battery flex and the home button contact, I've desoldered the battery so it can reboot because it isn't allowing me to. I've tried another screen as well. None of this has done anything and I'm kinda out of ideas as far as what to do. I find it funny how I had the same issue on an iPod I finished yesterday and it took a mere two minutes lol. Regardless I would really like your input if you have some experience with this issue to the extent in which I do. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
i am assuming you tried the standard reset?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yeah of course, nothing seems to be working though. Like I said the other iPods I've worked on previous have done this probably 20 percent of the time and all of them have been a quick minute fix by just shorting the far battery panel to the home button/charge port. This iPod has been very very annoying.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 93
