メインコンテンツにスキップ
Wi-Fi, GSMとCDMA モデルのiPad第二世代です。あるモデルはiPad3発売前に改良されたものがあります。修理は困難で、熱で温めてこじ開ける作業が必須です。
956の回答 すべて表示
Ghost touches and twitch after screen replacement
Hey,
I recently performed a screen replacement on an iPad 2 and everything looked good, but after I entered the pin for the first time, the device immediately went into the calendar.
Reading various tips on this site, I found that the "ghost touches" were often a result of contacts being triggered and that taping the connections on the underside of the screen would solve that issue. To test that this was the issue, I booted the device and entered the PIN while the screen was off (so that nothing could possibly be touching the contacts inside) to test that this was indeed the issue.
Unfortunately, the device went straight into the calendar again. When I turn the device sideways, the iPad doesn't go straight into the calendar (presumably because wherever the screen is registering a touch, no longer has an application under it).
Thinking that it might've been some sort of dust or residue on the screen, I've tried cleaning both the screen and the underside of the screen (using compressed air to eliminate dust and contact cleaner to remove any residues). This doesn't seem to have any effect.
I also notice that while the screen is off and the device is on, there's a little "twitch" to the screen. Like someone is trying to swipe the clock and the "Swipe to Unlock" button to the side. This could have something to do with the screen being off still, but I figured I'd mention it in case it's a symptom.
Does anyone have any ideas on what could be causing this issue?
Thanks for any suggestions.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
PCラップトップ用バッテリー
iFixitの品質保証付きトップPCブランド用バッテリー
ショップを見る
PCラップトップ用バッテリー
ショップを見る
1回答
選択されたソリューション
Try cleaning your touch screen connector on the board and re-seating your touch screen cable. If it doesn't solve your issue, there are 2 main causes for ghost touch on an iPad 2 that you need to investigate:
1/ At screen level: your touch screen is defective or the cable is creased due to improper installation. Try a new touch screen without gluing it in place, and without creasing the cable connecting it to the logic in any way. If this solves your issue, research on this site previous questions about how to glue the touch and prevent it from popping up.
2/ If all the above fails, the touch screen connector on the logic board is probably defective. This defect could be visible under 10x or more magnification, and then again it could be invisible.
この回答は役に立ちましたか?
スコア 2
コメント:
That did it. The screen was no good. I swapped it out for a new screen and the ghost touch went away. Going to try uncreasing the cable, but either way it turned out that the screen was bad.
Thanks for the help.
による
コメントを追加
回答を追加する
M Roche さん、ありがとうございました!
統計データを表示:
過去 24時間: 10
過去 7 日: 29
過去 30 日: 114
今までの合計 2,987
