How do I connect to WiFi?
I checked my device settings and I have the wifi turned on. I can see available networks but I can't connect to the wifi.
First off, make sure to check that your router is broadcasting a signal. Since you have checked your settings and are seeing the network you want to connect to, I would try a soft reset of your tablet. To preform a soft reset, go to the troubleshooting page and follow the instructions. Good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 263
