Cannot eject sim tray, jammed
Hi, please help
I cannot eject my sim tray.
I've been trying with default ejector tool, needle, and pin. I think i jammed or broke it somehow. And the hole juat getting bigger. nd
Anything i can do to get it out?
you can try method "from" iphone ? there are many guides and i think the thing work more or less in the same way!
このアンサーは役に立ちましたか?
what method? can you show some link?
because in my case, i think the sim eject button in my phone in somehow broken and can't be pushed.
using needle, the needle i use is broken to pieces
using ejector tool, it bend
このアンサーは役に立ちましたか?
I have the same problem. Never replaced the sim, so never needed to eject the tray for 2 years, Now does not eject anymore. Pins are bending and the hole is getting bigger. I would defintely go for a tear apart procedure but I see that the very first step is ALWAYS removing the tray first. What if I tear the phone apart without removing the tray ?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 96
