メインコンテンツにスキップ
Appleの iPhone 5sは2013年9月10日に発表されました。このデバイスの修理は全モデルの修理と類似しています。そしてスクリュードライバー、こじ開けツールが必要です。GSM か CDMA、16か32、64GBがあり、色はシルバー、ゴールド、スプレーグレイが選べます。
4093回答 すべてを表示
How to sort screws without reference
Hey everyone! After being helped so well on my first question here by @Rany, i felt confident this was worth a try. As i said in my first question i am building a Iphone 5S starting with only the motherboard and the home button flex. I have every part, except the earthing clip but i have ordered that, and had a pre-installed 5S back housing with small parts, a original 5S back housing with all parts,a new lcd with all parts, 2 screw sets and a set of all small parts in a 5S. The parts, and mainly the screws, i need guidance on. How do i distinguish screws from each other? Also in my test run with everything installed, except the earthing clip ;), the phone does heat up quite a lot and the screen is a bit jittery but that i think is because the connector shield isn't on properly because i cant find the screw that's supposed to go in top right. I know that its supposed to be de-magnetized but i cant find one that is :( Sorry bout the long post Thanks in advance for any insight.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
The repair guides here will give you the screw size. A digital / electronic caliper will allow you to measure the screws and match them to their appropriate place.
このアンサーは役に立ちましたか?
スコア 1
コメント:
Nice!Thank you for the solution! Any ideas on the over-heating? Also do you think it is essential the top right screw in the connector shield is non-magnetic?
さんによる
コメントを追加
回答を追加する
hari さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 419
