How to take out glued screws off my tablet
im trying to fix my tablet but I cant open it because the screws in the back are glued in so how can I remove the screws to open the back (screws have glue so they cant be unscrewed)
Is the glue over the top of the screws? If it is, just heat up the tip of a screw driver with a lighter and melt through the glue too the screw. If it is in the threads then the factory used some sort of thread lock. If so just place a thin piece of rubber over the screw head, push the screwdriver into it as hard as you can and slowly unscrew it. (The rubber will keep both the driver and screw from stripping.)
このアンサーは役に立ちましたか?
The use of a thin piece of rubber preventing stripping is the best advice I have ever come across the Net. Thanks Tucker
You're absolutely welcome! Make sure you pass on any tips and tricks!!! Big or small we will take them all!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 2,428
