Where is fuel pump located and diagram to replace old fuel pump
2001 Doge Dakota quad cab 4x4 fuel pump going out
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your fuel pump is inside the gas tank. You will either have to take the bolts out of the bed and jack it up on the drivers side. Or you can take the two straps loose from the tank, and unbolt the screws from inside the gas lid. And ease the tank down. You would also have to jack up the left rear of the truck to get it out. Hope this helps.
このアンサーは役に立ちましたか?
Can you also cut whole in the bed of the truck to get access to the fuel pump
過去 24時間: 2
過去 7 日: 19
過去 30 日: 65
今までの合計 2,876
