Why is my Xbox One not showing pictures?
Tv is not picking up the hdmi from the Xbox One
It's hard to know without being able to look at it. It could be a problem with the HDMI port, cable, etc. It could be a problem with your TV (make sure the input is set correctly) or you could have a faulty HDMI chip on the motherboard of the Xbox.
I would check all of the easy things first...try another cable, try wiggling the cable, check the HDMI port to see if it looks bad, etc.
I hope this helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 170
