メインコンテンツにスキップ
A counter-top sandwich grill that features a floating style press and 10" x 8" grids.
4回答 すべてを表示
Why is my Panini Press not opening up?
My Panini Press isn't opening up. I'm not sure if I closed it incorrectly or if the handle is broken; however the handle is stuck and won't lift. So, I can't access the cooking surface.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
選択されたソリューション
There are a few possible causes of this problem.
1. The Handle could be broken. Follow the guide on the This Page to replace it.
2. The Locking Knob could be tightened too far or rusted shut. Try to unscrew it as far as it will go, or follow the guide on This Page to replace it.
3. The Storage Latch could be closed. This latch is designed to prevent the panini press form opening when stored. Check to make sure it is all the way open.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Katie Howes さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 28
今までの合計 2,318
