Depending on the difficulty of what you need to pry (and the material you're prying) I've used a few things.
First off, for a good dental pick set, you can use the Craftsman one mentioned above, since they're a decent brand and I'm assuming they'd have a lifetime warranty. If not, I know you can go to Lowes and get a Cobalt 4-piece set for $6, including a normal hook shape, a right angle hook, etc. Link to item: http://www.lowes.com/pd_239658-930-32462...
Another really useful thing I use and lasts quite long, is guitar picks. Currently I just use the freebie medium thickness ones from Sam Ash, but for something more of a point instead of a curved point, I bought a pack of Tortex Sharps, the green color ones. Those can help more since the point can assist with the insertion where you're going to pry. Plastic picks are the way to go in certain cases like opening up laptop LCD trims, etc, since they run the smallest amount of risk of breaking the plastic latches, and will not scratch up metal trim of let's say a 1st gen iphone (of course you may need a thinner pick than the green ones, those are medium.
Bottom line, if using guitar picks, I'd rather them be damaged themselves than scratch and carve metal that you would end up needing to file down and then it looks worse. I use both these options depending on what needs to be opened.
Good luck with your search.
thanks - will try. Hope I find a big one somewhere in the house
Spikey2 さんによる
This should be a comment on the answer you are referring to.
Nat Welch さんによる
he made a mistake man- just upped that post to reverse ur down vote. No reason in penalizing somone for an honest mistake
rab777hp さんによる
Ya. I'm trying to find a way to promote comments where needed without angering people too much. Down voting without saying anything depresses people, while explaining that I'm doing it because it is a comment angers them. Not doing anything also gives people the idea that it's ok. If you have any suggestions on better ways to approach this, send me an email at nat@ifixit.com or post something in the feedback area (link is on the left).
Nat Welch さんによる
unfortunately you need 20 reps to comment (and 500 to edit your own post) - and when you are new ....
Spikey2 さんによる
