メインコンテンツにスキップ
Released in April of 2006, the S4011 was built for everyday tasks such as word document processing and internet browsing.
5回答 すべてを表示
want to upgrade wi-fi card
The wi-fi card on my A105 works, but is slow. I see that there are "N rated" cards available for as little as $20 but I have no idea if they will fit in my A105 model. Is there a standard for factor (size, shape, number of "pins," etc) for all wi-fi replacement cards? if not, how might I go about getting the proper card? Thanks in advance! Jami
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
I think your best bet here is to use a USB WiFi adapter Vs trying to upgrade your internal unit.
Here's a good write up on the very latest 802.11ac adapters: Tested: We push six 802.11ac Wi-Fi USB adapters to the limit. Depending on your OS version you may not be able to use these in which case you'll need to checkup the older 802.11n adapters.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jami Francis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 241
