My sony walkman seems to shutdown while charging
Whenever I plug in the Walkman to charge it, it shuts down after a few seconds. I don't know how to fix this situation. Please help!
Digital music, video and photo player with FM radio manufactured by Sony in 2012.
This could be the result of a number of issues
The USB cable is not connected to a USB connector on your computer properly.
Disconnect the USB cable, and then reconnect it.
Use the supplied USB cable.
You cannot charge the battery when the icon appears. Charge the battery in an
ambient temperature of 5 °C (41 °F) to 35 °C (95 °F).
The computer is not on or may in sleep or hibernation mode. Counteract these settings. Connecting your Walkman via a USB hub may not work. Connect the Walkman to your computer using the USB cable (supplied). You have not used your Walkman for more than a year. Depending on the conditions under which your Walkman is used, the battery may have been deteriorated. Consult your nearest Sony dealer.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 364
