Why won't my tablet turn on?
I try to turn on my tablet by just holding on the power button for about 3 seconds but it would not turn on. After that, I tried holding down the power button for approximately 30 seconds, but still no luck.
Your problem may be a drained battery. If your tablet won’t turn on, check to make sure the battery isn’t dead after continuous use. Plug your tablet in through its corresponding cable to either a computer or AC adapter to see if anything happens. If it still does not turn on, your battery may no longer hold a charge and must be replaced with a new battery.
このアンサーは役に立ちましたか?
I just used my tablet twice and now it doesn't turn on, or better yet said, it doesn't go past the adroid picture (when turning on)
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 12
過去 30 日: 14
今までの合計 2,417
