メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
313回答 すべてを表示
締切られた回答
Backlight Non-Functioning after Water Spill
I'm trying to fix a MacBook Air 6,2 (13", Early 2014). The previous owner spilled water on it, but immediately took it to a repair shop, where it was disassembled and dried. As a result, the laptop doesn't appear to have any corrosion, and everything works but the backlight. The LCD functions, so I can use the laptop as normal if I use a flashlight or headlamp to shine light on the screen.
I've done a bit of research, and it seems like this is pretty common after a water spill and happens because of a blown fuse which can be replaced (this seems to be the most successful thread).
I have access to an electrical engineering lab (and EE friends), so I have all the tools I need to test and repair the MacBook.
Can someone tell me which componenets I need to test with a multimeter in order to diagnose which one is the problem? Here are some pictures of the logic board:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
Highly likely the backlight driver IC has fried and will need replacing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 265
