メインコンテンツにスキップ
モデル番号A1137/1、2、4GB容量/カラーオプションはブラックとホワイト
64回答 すべてを表示
iPod doesn't turn on after battery replacement, What should I do?
My iPod nano turned on for a short period of time before it went completely dead, wouldn't turn on no matter what, connecting to the computer or charging. So I replaced the battery. The screen is also cracked. I have not yet replaced the screen since I'm still waiting for the part. Now I plug it in to my computer and still there is no sign of life. Any ideas? Do you think I might have ruined the logic board during the battery replacement or something?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Another possibility is that the connector pins inside the ipod have slipped from their place, by blending themselves. If you remove the black tape from the connector, you might find something like this:
I know maybe it’s way too late for you but, I have done lots of research and this kind of issue seems to be totally un-documented.
By the way, if it’s your case on anyone else’s searching for some luck then try to push them back in place and see if it enters in charging mode.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
That's possible. Pop it back open and make sure all connections are snug. Leave it on the charger for a while and maker sure it has a full charge.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I haven't put the back cover on yet. Do you think I should try again with the back cover closed?
さんによる
Just did it. Still dead. :( looks like it dies for good.
さんによる
コメントを追加
回答を追加する
Ira さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 136
