メインコンテンツにスキップ
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
37回答 すべてを表示
Why won't my laptop charge properly?
I charge my laptop for hours and it shows that the battery is drained or isn't charging.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
3件の回答
最も参考になった回答
Vanessa,
First, make sure the charger is completely plugged in. If it is, it may the outlet that isn't receiving power. You can test that by plugging something else into it.
If that still isn't working, you may have to replace the battery. The same thing happened to my computer. Replacing the battery fixed the issue.
I hope this helps!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I just replaced my battery. It worked well for nearly a month but now I'm having the same problem. It's plugged in but the battery is not accepting the charge.
さんによる
コメントを追加
I have the same problem. I just use my laptop 9 months. but now it's dont want charging (just keep 0%) and the battery indicator flashes. Do replace a new battery can be more durable ? Then how the technic of using the batteries so it's can be durable?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My ASUS R510C Notebook PC does not power up if I disconnect it from my household electrical receptacle. Do I need a new battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vanessa Garcia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 14
今までの合計 1,966
