メインコンテンツにスキップ
The Lenovo Ideapad Y410p is 1.29 inches thick and weighs 5.5 pounds. The device is known for its Premium JBL® Speakers, NVIDIA® GeForce® Graphics, and Intelligent Touchpad. Model number: 59399853.
Why won't the laptop power on?
When I plug in my laptop there is no power LED on either the laptop or the charger. However before I plug in the charger the light is on. Why does the charger light go out when I plug it in?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
When and how did this occur?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
i sounds like there may be a short in the dc jack or the mother board. id start by seeing if your dc jack is soldered to the mother board, attached to the board with plug in leads or on its own power board and looking in to replacing that first and going from there to suspecting the motherboard if the dc jack is on leads it can be easily tested with a volt meter. I would also test the ac adapter with a volt meter to be sure it putting out the proper voltage.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
if there is a short in the motherboard, is there anything that can be done ? the PC doesn't power on, just makes a strange clicking noise.
さんによる
When I plug in my laptop there is no power LED on either the laptop or the charger. However before I plug in the charger the light is on. Why does the charger light go out when I plug it in? and i check it with volt meter
さんによる
コメントを追加
回答を追加する
Keith Batryn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 855
