Why does the NutriBullet not spin the blade? No sound either?
Why does my NutriBullet not spin the blade and does NOT make a sound?
If you are pushing down on the aviators and the NutriBullet is not making any sound, you could have a problem with the outlet. Before you replace anything, try the plug in a different outlet. Still not working? It will be alright. Good thing we have you covered with a replacement guide for a faulty plug.
このアンサーは役に立ちましたか?
"It will be alright" not if it is still not working. What other possibilities are there? Why would you replace the plug? How about checking it? How about checking the cable to ensure it is a failed plug? You are only focusing on one thing and then get stuck with it. How about exploring other possibilities? What would you suggest if the plug works?
You may contact Nutribullet Customer Service Department at 855-346-8874 for assistance on using the product or warranty service. (Mon– Sun, 9am–8pm EST). You will be required to provide the barcode/serial number located underneath your Motor Base
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 806
