wardharold, first what is your TV's model? then explain the "white to bright" a bit more. Does your TV turn white, as in only the backlight is on or can you still make other things out on the screen. The better you describe the symptoms, the greater the chance to get a good answer. Remember we can not see what you see, so we can only go by what you tell us.
The VW46LFHDTV10A has an issue with a variable resistor to come of the board. Of course, you want to check all the connections, pay particular attention to the T-con board connectors.
oldturkey03 さんによる
sorry,yes you can see picture,but it`s like you turned brightness up 200%
wardharold さんによる
oldturkey03 さんによる
vizio vw46l fhdtv10a is md #
wardharold さんによる
oldturkey03 さんによる
2件以上のコメントを表示
