Touch not responsive after assembly replacement?
Got the frame lcd digitizer assembly, attatched everything perfectly, no touch. Put the old part that was working, just cracked, and now it doesnt work either. help please???
the new lcd assembly you got is faulty
このアンサーは役に立ちましたか?
but thats the thing, i dont think it is. because when i put the old one that worked back on, it also didnt work
Have a look at the connector on the board. If you have tried the old part and that still shows the fault it seems more likely to board level. Have a look under a magnifying glass to see if you can see any damage on the connector. If that looks okay try cleaning the board with some isopropal alcohol. If none of these work it seems to be a board level fault
このアンサーは役に立ちましたか?
Thank you i will try that
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 157
