メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
430回答 すべてを表示
Power supply or logic board?
Hi all,
I'm trying to determine if I have a bad power supply, or logic board on my iMac, big difference in the price to fix and if its the logic board, its probably not worth it. My iMac is now out of warranty and suddenly won't power up. I've read through all of the threads I could find and done as much testing as I can to this point. Powering up the iMac results in no power, hard drive doesn't spin, fans don't spin, no noise whatsoever. LED 501 is lit, but none of the others. I've tested for continuity on the power switch and it seems fine, I've tried the reset procedure to no avail, I've also tested voltage off the power supply, but I don't know what to look for and some have power, others don't.
Any help would be greatly appreciated.
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
I'd replace the power supply as you don't seem to be getting any power past that. Here's how to do it: iMac Intel 21.5インチ EMC 2428の電源ユニットの交換
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you for responding, I really appreciate it. I have the current power supply out, do you know of anyway to test it for proper voltage output?
さんによる
コメントを追加
I have a similar issue (no chime, only LED 501 is lit) except that I hear the disk drive and the optical drive spinning (but fans are off). Does is mean that the power supply is working and that it is the logic board that is dead?
Thanks a lot.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No. The first LED will light even when bad.
LED 1 indicates that trickle voltage from the power supply has been detected. This LED will be ON when the computer is turned off and your power supply is working correctly.
LED 2 indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 indicates that the computer and the LCD display are communicating. This LED will be ON when the computer is turned on and video signal is being generated.
LED 4 lights only if the computer detects an over-temperature condition. This LED will be OFF when the computer is turned on and running at the correct temperature.
さんによる
コメントを追加
I have the same problem but in my case the LED lights not turn on none of them …what could be
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tim14 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 710
