メインコンテンツにスキップ
Dell社によって製造されたラップトップモデル一覧です。
3030回答 すべてを表示
Dell Inspiron, Win7, Battery not charging (62% plugged in, charging)
I have an Inspiron 15R and my battery is not charging. I have the genuine Windows 7 that came pre-installed and Windows, the battery icon in the task bar, reports a constant battery level of 62% (plugged in, charging.) The adapter is the original that came with the laptop and when I remove it, the laptop looses power and it simply dies.
I have run a diagnostic from the BIOS and it says that the battery is working fine, but even with the adapter plugged in it reported an idle state.
I saw on a windows forum that i should:
- turn off the laptop,
- remove the battery,
- start up with the adapter,
- open the device manager,
- under batteries uninstall "Microsoft ACPI-Compliant Control Method Battery"
- shut down the laptop,
- re-insert the battery,
- start up again.
Even that didn't change the state.
Any advice or help would be very much appreciated.
Thank you.
-Tharindu Wijayasekara.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント:
Tharindu, I have the exact same issue, only on a Dell XPS 13 that I bought off of eBay. Mine says it's charging but stays at 21% and then dies when I unplug the AC adapter.
I too tried all the same things you did to no avail.
Did you try a new battery, and did that solve the problem? If I could solve it with a new battery I'd go that route; otherwise, I need to return the laptop.
Thanks,
--Greg
さんによる
Hi Tharindu, I am facing the same problem on my Inspiron 14z-N411z. I have used my laptop for three years but only to back up my files (word files) and some browsing here and there. I am a lawyer and I only use Word on my laptop IF I need to work from home, which is very rare. So you can imagine how less my usage is of the laptop. And all of a sudden I face this battery problem. Started 6 months ago I guess. If you find a solution for the problem please do let me know. I'll be eternally grateful too. Thanks. Jaideep.
さんによる
To combat this issue, you can use a cooling system and test whether or not your device is able to charge with the help.
Method 2: Adjust your power settings.
Method 3: Update the battery drivers.
Update battery drivers manually.
Update battery drivers automatically.
Method 4: Turn off battery life extender.
Regards,
Rachel Gomez
さんによる
コメントを追加
5件の回答
Hello,
these battery's are really designed for a 2 year life. after a while the full 100% charge disintegrates. most battery's are 4800 mhz fully charged new. Over time it will be anywhere from 0 to 4800 mhz. meaning it could read 400 mhz 100% charged. There are cases where the battery readings are so far gone they give false positives. I believe that's what is happening in this case, specially if when you unplug your AC adapter while holding a 62% charge your battery has become defective.
An alternative check is to load Ubuntu a free Linux OS. Run the integrated battery test within the OS do a search for power it should pop up. (all New E-stewards standards are using this) and see what the readings tell you.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
i have a new battery and have the same problem with dell e6320.
さんによる
how to run integrated battery test??
さんによる
Absolute nonsense - the "4800" refers to power available over time (mAH) and has nothing to do with frequency (mHz).
さんによる
コメントを追加
I've been facing same problem for last couple of days with my Dell Inspiration. would be grateful if anyone finds a solution!!
RA
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I searched on Google some solution is update your BIOS, it doesn't work for me but worked for some people, try it.
you can find your bios update in your manufacturer's website
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello,
I would recommend a battery replacement to start as batteries are relatively inexpensive. I had a similar problem to an HP Pavilion G7 and a battery replacement fixed the problem. Let me know if you need help!
~JS
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check the settings in BIOS, look for the AC adapter and make sure it shows the proper wattage for it. Check to see if the battery shows up or if there is a problem. You can also use the built in diagnostics to check the power as well as other problems. To get to BIOS or Diagnostics, press F10 when you see the Dell splash screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tharindu Wijayasekara さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 7,074
