メインコンテンツにスキップ
Oculus RiftファミリーのVR機器の修理・分解情報です。
60回答 すべてを表示
締切られた回答
Why isn't my view in the game following my head movement?
When I am playing any game, I move my head to look at the things surrounding me, but the headset thinks that I am still looking forward. The display is working just fine. I simply cannot look around.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This is most likely due to a problem with the device tracker. Since your display is working, the wires connecting to the tracker board should be fine, so the problem is the tracker board itself.
I suggest trying to re-calibrate the device first since faulty calibration could cause the tracker to move in the wrong direction. To learn how to calibrate your device, click here.
If your problem still persists after calibrating, you should replace the entire tracker board itself - refer to the Oculus Tracker V2 Board Replacement guide.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 181
