ripped diode to the left of the digitizer fpc?
Hi everyone, I seem to be in a tricky situation here. I was repairing a 5s because the touch wasn't working. It was also cracked. At first I thought it was just the screen, but a new one doesn't work the touch still. So when I peel up that black protection sticker covering the diodes and ICs, one of the diodes somehow was stuck on the glue. I'm assuming it's because the chip is ripped off is why the touch is not working. Unfortunately the pad is ripped off too, so no luck trying to solder it back. Does anyone know where the bottom pad trace leads to? The top one looks good still. Maybe I can just run a wire to it?
Ah ok. Thanks for the info. So if I have this right, this is what should be done? And I wasn't sure if that was C306?
Patrick さんによる
Agreed but, chances are they most won't need to replace the capacitor, as it most likely wasn't connected to the pad that remained on the board or it wouldn't have come off the way it did.
ABCellars さんによる
