メインコンテンツにスキップ
Kindle Fire HD 6 (モデル番号PW98VM)は6インチのエコノミータイプのタブレットで、2つのカメラ、1つのスピーカーとAmazonのFire OSが搭載されています。
21回答 すべてを表示
Why won’t my Kindle Fire HD6 turn on?
I have charged the device in multiple outlets, but it still won't power on again--I am not sure if the device is even holding a charge. Any suggestions are appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
I bought my Kendle fire two say ago and now it won't turn on. What do I do?
さんによる
コメントを追加
7件の回答
最も参考になった回答
First, make sure that the Kindle Fire is charged. To check that it is charging, make sure the charger is plugged into your device correctly, and that the outlet you are using is providing electricity. (Try plugging in something else to the same outlet and making sure that it works.) If your device is charged, but still not powering on, there is most likely an issue with the motherboard. There is an even higher likelihood that your motherboard may have failed if your device has been subjected to any water damage or a powerful electric shock. For more information, visit our troubleshooting guide.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I know this is probably too late for you, but I have seen an issue with this tablet where it is actually turned on but the screen doesn't light up. You can tell this is happening because if you keep pressing the power button (holding it to initiate a shutdown) you here the beeps from the pop-up window confirming if you really want to turn it off.
If you press on the edges/slightly twist the tablet you can get the screen to turn on again and it will work fine for a period of time.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Plug it in like normal and wait a while then hold the button for 30 seconds or so then wait a minute then hold it again. If that doesn't work click it over and over just annoy it it should turn on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had this occur to me before. Plug you device in to the USB and brick it came with, plug the brick in to a outlet, and then hold the power button for 30-40 seconds, and it should turn on. If it doesn't, you may need to contact Customer Support.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Fire HD 6 (4th Generation) can not see Wi-Fi and it is working (1000% on my computer) I add, again, the information of the Wi-Fi from my company, but nada, nothing.  Please help.  Thank you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I do not have an answer but surely am frustrated. I replaced the screen on my kindle fire HD 6 and made sure to follow the directions exactly, even triple checked my work. The fire will power up (i can hear messages coming in) but the screen will not light up. Am about to take it all apart yet again but this is really a big problem as this is my favorite kindle!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My kindle was fully charged when it decided not not turn on….so this “charge it up thing” was of no assistance. Thanks for trying though. KC
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cassandra Beck さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 6
今までの合計 7,021
