メインコンテンツにスキップ
The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
Why isn't the keyboard dock working?
My transformer pad is connected but i cant use the keyboard because it won't pop up i can only use the 'e' and 'l'key. Also sometimes when i connect the keyboard dock the screen freezes and shuts off and wont turn back on again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
I have the same problem. The "c" types in ";" the "x" types in "q" and the space bar doesnt wok. HELP ME
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
same problem. can someone help me pls
さんによる
コメントを追加
Make sure you haven't downloaded any alternate keyboards. If you have, disable all but one. Other than that, that's the only thing that helped mine. K0101......
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The last couple that I have repaired have had weird keyboard faults and they both turned out to be poor seating in the edge connector under the keyboard. Pull off the four rubber feet and undo the screws. Take out the two visible ones underneath and the three under the silver tab directly beneath the touchpad. Unlock the ribbon edge connector and clean the ribbon contacts.
It may be as simple as that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jennifer Hernandez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,199
