メインコンテンツにスキップ
The second generation of Corvair with an improved suspension and new body style was released in 1965. It's air-cooled, rear engine design is similar to that of a Volkswagen, or Porsche.
7回答 すべてを表示
締切られた回答
Trunk latch key turns but won't budge
Hey guys! Working on a Chevrolet corvair 1965 that has been sitting in my grandpas storage unit for about 20 years. He has 2 of them for parts and stuff so we've been slowly merging the two but he thinks there are parts in the trunk of the one that won't open! The key turns but the latch has fallen through or something we have no idea. Is there any other way into the trunk that you know of? Trying to avoid brute force but will do whatever is necessary. Thanks for your time and help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Turn the key until it releases the hood. Then, hold the hood down just a little bit and turn the key as far to the right as it will go.
This failing you may have to remove the headlight to get to the bolts.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 968
