メインコンテンツにスキップ
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
76回答 すべてを表示
Is there any chance of repairing or replacing the battery connector?
When replacing the battery in my Samsung Galaxy Note 8.0 the black piece of the battery connector broke in half. Now it doesn't have enough force to hold the pins down to make a reliable connection. The device only works when plugged in. As soon as I unplug, the device powers off. Any tips would be great. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
That was the 1st thing I tried. It worked for about a month. I ended up soldering the contacts.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if you bought the phone within the past year or two it should be covered under warranty with the company that you purchased it from. speak with them about it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just fixed mine. Looking around, it seems the Samsung repair depot will solder the contacts (battery and wire connector) together. This will be a reasonable fix until you need to replace the battery again.
My solution was to take a small patch of EVA foam and double sided foam tape just big enough to cover the terminal. Apply this to the top of the battery cable connection.The back of the tablet casing should press on the foam enough to keep the contacts together and the tape will stick to the outside of the tablet battery connector.
Time will tell if this is a reasonable long term solution.
(I wish I could post a pic of this.)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
B J さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 365
