How to drain gas tank?
craftsman riding mower, water in tank
この質問は役に立ちましたか?
Simple usually. Just look below the tank and before the carb. You should see a clear tube with fuel in it. It will have a pinch type collar on either end. Simply squeeze the tabs of the collar with a pliers,pull the hose free of it's male fitting and let drain into a bottle of some sort.
このアンサーは役に立ちましたか?
What if it don't have one of those tubes it has water in it we tried to drain it by putting the frount wheels in a skidsteer but results wasn't good
Here is a great video on how to do it safely: https://www.youtube.com/watch?v=zCA0Sw8h...
Whenever equipment is sitting unused over several seasons or especially several years, the gas should be drained as it can create a lot of costly damage to the motor.
このアンサーは役に立ちましたか?
過去 24時間: 12
過去 7 日: 110
過去 30 日: 365
今までの合計 21,829
2 件のコメント
A model number would help us help you.
mayer さんによる
917276844 that is the model number if you can help today id be really happy we need it runing
brandon lee howard さんによる
