メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5s motion sensor doesn't work
Hello, I succesfully changed my iPhone 5s battery. Everything went ok, I just had a little trouble taking the battery out, but didn't damage anything. I followed the guide backwards and went plugging everything in step by step.
I closed the phone and everthing works just fine. The only thing that doesn't work is the motion sensor. I have noticed that neither the compas or the Health app detect any motion. Plus, when I turn the phone, pictures don't turn as well.
I checked and turn is not blocked and I haven't changed any motion related settings, I'm positive it's a hardware problem.
Thanks a lot in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
You can damage the motion chip that is located near the screen connecrors chances are you have damaged it
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi! Thanks for answering. That was my fear at first, by then I found (link in my comment to the post), that there is one of the screws keeping the screen connectors wich is magnetized. If you place this screw in the slot near the sensor motion (upper right), I will cause the sensor to stop working. I just switched that screw for any other and now is working again. Thanks again!
さんによる
コメントを追加
I just experienced the same symptoms: Replaced the battery, and afterwards none of the sensors worked.
After searching more than just the "how to" videos, I found ifixit's step-by-step online guide. I cannot emphasize enough: The four (4) screws securing the RFI shield over the cable connectors are *3* different lengths. The differences are too small to see with the unaided eye. But if you put them in the wrong holes, you can disable the sensors (best case), or damage the logic board (worst case!).
Fortunately, I have a set of micrometers, and was able to measure the screw lengths precisely. After disassembling again, measuring each one, and reassembling with the right screws in the right holes, all sensor functions were restored to normal. Hallelujah!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jorgelopezcanales さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 5,952
