メインコンテンツにスキップ
Samsung 製デジタルカメラの修理ガイドならびに製品サポート
401の回答 すべてを表示
samsung pl55 lens problem
I have a SAMSUNG PL55 digital camera. The camera fell with the lens open and now the lens doesn't go back. It was stuck. I opened it and I feed the lens motor with 5V directly from an AC/DC adaptador (the battery is 3,7V). The adaptor I get in home has the closest voltage I could get. When I feed the motor the lens with the properly polarity the lens go back and so I saw that apparently everything (mechanical part no jammed) was okay with the motor and the lens. But when I put the battery and and power on normally the lens go forward and the 3 or 4 beeps issued and the lens can go back. What can be wrong? I let the battery charging 100% just to be sure then I tried but the problem persists...maybe something wrong with the electronic sector that commands the lens motor?!?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1回答
try to see here http://mans.io/brand/Samsung
if you cannot find info you need - just write to support and they will help you
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nuno Sandro Baptista さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 274
