メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
Sim ejector arm stuck in wrong position, how to proceed?
Hello iFixit,
I bought a banged up iphone to repair it into perfect condition. In this I was successful, but now I can't eject my sim-card tray due to the rocking arm that was in the wrong position when I put the tray in.
If you're unsure as to what this is; it's the arm that pushes the tray out, when you push on the other end with the tool or a paperclip. Since it's already fully depressed it doesn't act upon the sim-card tray. Now I haven't found a screw that fits properly as the most "upvoted" suggestion suggested and other methods doesn't work.
Since the tray is connected to the motherboard, I can't disassemble the phone to correct the mistake and thus I'm stuck at the end of a blind road.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Can't you just push it out from the back of the phone? take the case off and push it out from the side of the logic board.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Do you mean the procedure with a plyer? Where you remove the backcover and press it out? Because I already tried that yesterday and it didn't budge.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 141
