メインコンテンツにスキップ
The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
38の回答 すべてを表示
Nook HD 7 charge port parts
Is there anywhere that sells just the plug / port? Not the cable but the part on the motherboard that the cable plugs into.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Did you find an answer? I have the same problem and can't find an answer.
この回答は役に立ちましたか?
スコア 0
コメントを追加
Yes, I found a used nook @ yard sale. B4 tearing down the yard sale nook, I √ to make sure it was going to charge 1st. Then I removed the port from that one & replaced my bad port. Take ur time & be very very careful. I found an online video to break down my nook. Power99 had a good video on youtube. Its been so long ago I don't remember if I used a small piece of electrical tape or a dot of electronics glue to hold it in place as I had no way to sauder it back. Works fine now.
Tools:
**Tweezers w/curved tips to grip the port 4 removal & replacement.
**T5 or T6 magnetic screwdriver
**Flat plastic pry tool w/ a smooth rounded tip NOT a fingernail file!!
**Tape or magnet to hold the 22 screws from the frame of ur nook.
Just remember to go very slowly & don't rush.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jim さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 142
