メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2521回答 すべてを表示
thermal data , wdt timeout
i have an iphone 5 with crash panic.ps wdt timeout and crash stacks.backboardd thermal data unavailable.
i already replaced battery but didnt fix it !
+ my %percentage battery isnt working !
what do you think i can do , or what is the problem
the iphone is restarting one time at 2-3 minutes maxim .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
This isnt an answer but a work around. I switched my i5s battery on 10.2 and lost batt stats still have percent working somehow the value for "mah" switched to the %value so it looks like a failing 100/1570mah batt. Every boot i have till min 6 or when i run a semi cpu intensive app before it force restarts without warning. Sound familiar?
I keep an app called system stats (green icon phone with heartbeat monitor line) on my first page which helps me get the timing right it shows the uptime
upon boot i unlock (leaving it locked reboots)
Open system stats>scoll till cpu and the uptime reading are both visable
Open app switcher and swipe all other apps
Return to sys stats cpus should be running high watch it drop to the 60s then 20-30s then 10-20s at this point its around a min-two on uptime
With the system stats still showing i hit power button to sleep
Now you wait
Any notifications that turn on screen just re-sleep phone dont bother clearing or anything. If its an issue enable airplane mode.
Once you are passed 7-9 min you should be ok and your phone wont reset.
Like i said its a work around but it does work getting it to try to deep sleep asap works because iphones post boot if you dont unlock will continue background startup then sleep after the backgrounding time limit is reached which is beyond the 4-6min when it will restart.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
andreiswat さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 12
今までの合計 1,906
